TwinTurbo.NET: Nissan 300ZX forum - Sounds like a failed turbo.
MixManMash
on February 19, 2018 at 7:39 PM
300zx tt sputter and won’t boost
posted by Lowlife1998
on February 19, 2018 at 06:08 PM
I would definitely investigate why it died. I have seen stock Z32s without the coolant bypass completed where the metal hoses under the plenum are completely plugged, which can lead to turbo failure from lack of coolant flow.
Lowlife1998
18:08:29 02/19/18
Sounds like a failed turbo. -
MixManMash
19:39:01 02/19/18
I should point out that usually that is from lack of
MixManMash
19:39:46 02/19/18
Re: Sounds like a failed turbo.
Lowlife1998
22:10:37 02/19/18
That's a loaded question.
MixManMash
15:08:19 02/20/18
Re: That's a loaded question.
Lowlife1998
16:27:57 02/25/18
If you can't build boost (gauge stops at 0)
FrozTTy
19:14:01 02/28/18
Re: If you can't build boost (gauge stops at 0)
Lowlife1998
00:49:00 03/01/18
Ok.... and pass. side?? (n/m)
FrozTTy
12:26:49 03/01/18
Re: Ok.... and pass. side??
Lowlife1998
17:31:35 03/01/18
